주요 콘텐츠로 건너뛰기
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56 질문 전체 보기
질문 마감됨
USB Connector Cable torn down
Hey guys,
I have made a disply replacement on my Lumia 920. Thanks for the tutorial. It works!
Unfortunately I torn down the USB Cable at the begin of the disassembly. I bought a new one. The same problem with the new one. In the moment when I am closing the case the cable is squeezed and then its torn down.
Is it possible to make a soldering or to use any glue?
Best regards
David
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi,
You can not use soldering option here unless you are willing to risk your device for soldering however you have to buy a new usb cable and connect it if you think you can not achieve that percision then take it to a local repair shop for fitting the case after plugging usb cable. Try to keep a steady hand while fitting if you give it a retry.
Good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi,
thanks for your quick reply. OK I will try it a third time with a new usb cable. Hope not to squeeze the connector.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 396
