주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
Test give me this error: 4SNS/1/C0000008: Th1H - - 124
Hello, first of all, my English is not so good...
I have a Macbook Pro mid 2012 model A1278 Serial's # last digits are DTY3
The hardware test give me this error: 4SNS/1/C0000008: Th1H - - 124
Can you tell me something about this error?
Thank You Very Much...
Pablo
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
It appears one of your temperature sensors has gone bad.
To debug the error code you need this writeup: AHT error codes. So in your case 4SNS is a system sensor after the : mark T is temperature and the h is heat pipe (heat sink).
I would install a good temperature sensors & fan monitoring software to double check things. I like Temperature Gauge which you can download from the Apps store. There are others out there that are just as good. See what it tells you and let us know too.
I recommend backing up your system and after that you may want to open your system up to inspect it for dust and debris build up on the fans & heat sink fins as well as the logic board it self. If things look clean then the sensor most likely needs to be replaced. It's a bit of work here as you need to pull the logic board out to get to the heat sink and you should apply a fresh coat of thermal paste on the chips if you go this far. Review this IFIXIT guide Heat Sink Replacement
If you do see a lot of stuff you should get a can of can'ed air and a soft paint brush to lightly scrub the fan, fins & logic board and using the can'ed air blowing out the junk.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Hi,
I have the same issue and AHT result showed me the error :
4SNS/1/40000000: Th1H-127.875
can you please suggest what should I have to do in order to fix this ?
Can I perform thus fix at home or I have take my MAcbook pro to apple care support (my macbook pro is not under apple care plan)
Looking forward to your valuable comment to fix it.
Regards,
Harry
Did you install TG Pro (Temperature Gauge) what does it show? For less than $20 US it offers quite a lot of info to isolate the problem.
Hi. Did you solve the probelm ?? I have the same issue and i want to replace the smd on the board because i didn´t know if this work.
Greets Robert
@roberttomsich - I’m sure both have! But until you properly diagnose the issue throwing spaghetti at the wall won’t help you! Did you install TG Pro? Which is the current version of Temperature Gauge, what does it tell you?
Give. The location of the sensor it can often encounter liquid spill events which corrode the device and/or solder joint connections. But again without doing the basics of diagnostics and inspection it’s just a guess.
댓글 달기
귀하의 답변을 추가하세요
Pablo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 38
전체 시간: 18,281
