주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Can not power on after replacing power button
my iphone 4s was having problem with the power button, i have to press very hard to get it to work. i got a replacement power button flex cable and replace it. but after the replacement, the power button completely stop working. I swap back the old cable/button, its not working either. What could be causing this? thanks
  • it does power on after i plug in the cable to the computer.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
There are a couple of issues. A couple times I have looked at this issue it ended up being that one or both of the screws on the power button retaining bracket were not installed. Does the button make clear clicks when depressed? It shouldn't be hard.
Check your cables for folds, tears or rips. Check the port the cable plugs into for dust, debris, or broken solder points. Is this phone still recognized by iTunes?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
cli168 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 81
