주요 콘텐츠로 건너뛰기
Model A1311 / Mid 2010 / 3.06 및 3.2 GHz Core i3 or 3.6 GHz Core i5 프로세서
342 질문 전체 보기
replaced the power supply, but still nothing.
So as the subject says, i had my computer go out on me. It will not start up at all, not even turn on. No fans, no sounds coming from the computer. It's like the outlet was dead and I was getting no power.
However it was a live outlet, which is not the case. I ordered a power supply with tools, replaced it, put the computer all back together, and still nothing. Tried it in different outlets, still nothing.
What do you think could possibly be the cause? Would it be a bad logic board if the computer doesnt even turn on?
I saw no diagnostic LED lights turn on whatsoever.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Do you have a DVM? So you can measure the AC voltage at the power supply be very careful here!. Then check the DC side is voltage present there. If not then the power supply you got is bad.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
raphaelaaron 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 130
