Is there any repair for netgear wireless router?
router is not receving power from the cable. can the router be repaired? if yes how much does it cost????????
awaiting your reply...
좋은 질문 입니까?
좋은 질문 입니까?
To start with have you tried a second power transformer. If you look on the bottom of the unit you should find a diagram which will tell you the units power requirements. I would suspect it needs 12volts 1Amp and the plugs inner core is the positive contact. Please double check this and locate the needed unit. What happens when you plug in the other unit and you press the power button? Does any LED's light up at all?
해당 답변은 도움이 되었습니까?
Any luck getting a new power transformer?
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 943
댓글 8개
please anyone do suggest me to solve this problem
vamsi krishna 의
Can you give us the products name & model number of your unit.
Dan 의
NETGEAR Wireless-N150 Router WGR614
vamsi krishna 의
vamsi krishna, "not receving power from the cable" are you saying that the router does not turn on? Receives power from what cable?
oldturkey03 의
Here's a good resource Netgear N150 Router documentation
Dan 의
댓글 3개 더보기
