주요 콘텐츠로 건너뛰기
모델 M7572 / 400 또는 500 MHz G3 프로세서
Will not boot up despite active power soure
I have tested the power source and it works well. I plug it in and press the on/off button and nothing, not even a faint noise, occurs. Everything seems dead. From past experience what is the most likely cause and is it worth trying to find a fault and repair it?
William
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
On board dc-in circuit, faulty power button/damaged top case. If someone has been in it before you they may not have completely or correctly reassembled it.
It will take a lot of troubleshooting, examination to determine where the first or major problem lies. If the battery is charging that could eliminate the DC-in board as suspect.
If this Answer is helpful please remember to return and mark it Accepted.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
william isbister 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 204
