dvd wont play in e drive
i can't play dvds
좋은 질문 입니까?
You may just need the drivers. Install vlc and you should be all set. http://www.videolan.org/vlc/index.html
해당 답변은 도움이 되었습니까?
As you didn’t provide more info, I would recommend you to:
a. check if your disc drive, or if the DVD disc is damaged and repair the drive/disc if necessary;
b. check if the DVD is from another area, namely if there is region code protection on it; if it is, change the region code of your DVD player
c. try another DVD player like VLC;
d. convert the DVD to digital with Handbrake, MakeMKV, WinX DVD Ripper, etc.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 337
