주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
548 질문 전체 보기
LCD screen backlight no power
I had to take a part my mac to change hard drive, i disconnected the lcd display backlight connecotrs and marked them.
Now when i try to start my imac again.. it seems to not get any power on the screen, also i am not sure the computer is botting up at all sonce i can see the fans going buit i dun hear the apple sound related to the boot up process.
Do the 4 connectors have a specific order i might have messed up?
Could it be something else? preventing the imac form booting up and energizing the screen?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Yes could be any cable you disconnected, go over your connections again. Many times DIYers "think" they have solid connections when they are not square or complete.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I have taken it apart several times, and checked the connections, besides all you need to disconnect for the screen are the 4 ac power connectors plus the data one, so i was wondering if there is a safe way to check the voltage on those connecotrs in a safe way since i have been told they are supposed to be very high power and a regular tester would not work.
I own a Fluke tester 77 series.. would it be safe to test them with it?
댓글 달기
귀하의 답변을 추가하세요
Javier 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 157
