Why does nothing happen when I switch on?
Hi,
Nothing happens when I switch on : it simply does not start; no bip, no noise at all, no fan, nothing.
Checked:
- laptop correctly wired; switch button pressed; no result
- battery in; battery out : no change;
- battery out and switch button under pressure for 3 minutes then laptop wired : no result
- Test with a multimeter : electricity goes up to motherboard but I can't go further
Should I check anything else ? Has motherboard crashed? is it worth mending ?
Thanks for your help.
좋은 질문 입니까?
Have you checked to see if you have power at the DC jack on your motherboard?
oldturkey03 의
Do you know what caused it. Perhaps you took it apart and put it back together wrong (if you actually took it apart). You have a DV9 so it is at least 4 years old. I would say if you cant get it fixed without buying parts less than $30 then its not worth it. I have taken many of those apart and no your motherboard should not be shot. It is a simple cable that was not plugged in correctly or got loose. If the PC is not charging or not turning on then it is definitely a cable.
Charles B 의
Hi, thanks for answers. Well, I have power on the DC jack on the motherboard. I confirm my laptop was taken apart because it did not run anymore. Everything has been put back all right, plugged in correctly.
Wallez 의
