주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone 5 Digitizer going crazy after power button replacement
I replaced an iPhone 5 power button and after the repair the touch screen wasnt being responsive. I tried another screen and the same thing was happening. it works good when the screen is plugged in but, when i fully install it the screen decides to go all crazy on me.
Is something being shorted out? Please help?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
가장 유용한 답변
It seems the connector of the digitizer was loosened while you put the screen back.
Update
Hello, dariy! The one possible reason is that you mixplace the screws (3 screws in different sizes) on the mental bracket which is fasten the screen connectors. Or you have screwed the screws too tightly. Don't make them tightly.
The other reason is that the camera below the screen has not been placed in an exact location. But it is long odds.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi Dariy,
I just encountered the same problem. My iPhone 5 powers up and either the digitizer is not responding or the LCD doesn't come on and I hear the "bounce" charging sound every 5 seconds.
I tried what Vege Cai suggested but I had no luck. I also tried a few different display assemblies which are 100% functional (original) and I get the same problem.
Thanks!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I'am having the same problem. Anybody knows the solution?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
What problem? There are more than one problem stated above. If you want exposure (and an answer) for your question, I advise you to start a new question and state your problem in detail, saying what your device is, how old it is, what the issue is, how and when the issue started, and what you tried to do to fix it so far.
I'm sorry, ok, I will open a new post explaining exactly my problem.
댓글 달기
귀하의 답변을 추가하세요
dariy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 1,378
