주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Lines in display and no touch response
I'm repairing an iPhone 5 that was caught in a car door. The display assembly is fine but the back case has a small bend, that also slightly bent the logic board. The phone powers up fine, but there are lines in the display image, and the digitizer does not respond. These issues are board related as I have tested the display (am using it right now on my own iPhone 5)
Video of the issue here
My next step is to remove the emi shielding to have a look but was wondering if anyone had a similar issue and what the resolution was?
Thanks, first issue I've had to post out of 500 plus repairs that ifixit has aided in some way or another.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
가장 유용한 답변
Are u saying you tryed your good display in the iPhone and you still got lines in your screen?
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Yes I have tried multiple display assemblies on the faulty bored and the same result each time. The digitizer will not respond and there lines through the images. The slight bend in the board must have caused some severe damage..
Ah ok it defiantly sounds like board damage
댓글 달기
You may be in luck. It seems the first connection you connect isn't pressed down all the way. I've had this happen numerous times. Open the phone and reconnect it all. The technique I use is while holding the iPhone in one hand, press down to where the ribbons kind of bend and firmly press the connectors down in place with the other hand. After all are pressed down, check the phone display to see if its fixed! Hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have come across the exact same problem described here, any help on how to fix this issue please?
Update
Yes, same here. I have found this website selling for capacitors for replacement. Do you think that they should fix the issue?
http://www.cyberdocllc.com/shop/iphone-5...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Curtis Doran 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,894
