주요 콘텐츠로 건너뛰기
The Motorola Droid 4 is a smartphone made by Motorola that was released with Android 2.3 and is upgradeable to Android 4.1.
How do we Replace either the Micro-USB OR micro-HDMI jack?
Before commenting, please know: I KNOW where to order the jack parts, I just need to know HOW to replace them.
2nd and sometimes even 1st of the major two problems of the D4 was not just the battery, but relatted, the micro-usb port failure.
Although there is an excellant micro-usb cleaning video on YouTube (and that does work in most cases), what is clearly lacking but needed should be within the teardown, we need to see how to replace the micro-usb and micro-hdmi jack ports. We don't even see pictures of their freedom! Frankly only mentioned as to their existence. Please add to and change the teardown to explain this procedure (should be part of the teardown, shouldnt need to be a separate video)
Also , where can we get the exact same OEM jacks -I see alot of Razor links, but nothing for D4 yet.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
pretty much impossible, they are micro soldiered to the main board. I have tried doing the same thing on a htc evo 4g and even the nano fabrication lab at my technical school could not perform the repair.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
So, then, I would need to just order that board (35.00 OEM on Amazon)?
if you are talking about the main board yes!
댓글 달기
답변을 추가하세요
Dan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 396
