주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
HD will only work when case is open. After SSD replacement?
I've replaced the HD with an SSD in my MBP. If the case is open, it boots up perfectly. Once I screw the case closed, I get the Folder with Question Mark and the drive cannot be found.
please help!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
looks like the SATA cable is being pinched a little too much with the new drive. I rectified the problem with adding black friction tape doubled around the sata drive ribbon. Will replace cable.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Mike good catch! Give your self credit and close your question as answered.
댓글 달기
귀하의 답변을 추가하세요
Michael 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 175
