주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 모델 i9505는 13-megapixel 후면 카메라 및 5-inch 1080p 화면이 특징입니다.
526 질문 전체 보기
Same glass on the S4 Active as the S4?
I have a S4 Active and am not finding much information on ifixit for the device. I broke the glass on my phone and would like to replace it. The LCD still works. Does anyone know if the S4 glass is the same as the S4 Active? Can i buy the kit for the S4 and will it work on the S4 active?
Thanks in advance for the help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 5개
I had the same problem and the shape of the standard S4 glass is different from the S4 Active because of the buttons. I've also read that the glass is different and that the glass can't really be replaced without the digitizer. I'm still learning as I go. I haven't found a glass-only kit. Only Glass + Digitizer
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
No, both glasses are different.
How did you open the S4 Active?
Thanks for your answer
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
how about lcd and digitizer are s4 and s4 active the same lcd and digitizer? I know front glass is different.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi NO Difinitely different. Not only that but you also have a back light on the s4 active like an iphone. So if you spray alcohol or glue remover onto screen without removing backlight you are going to damage it. Just desolder the backlight first...remove glue and replace the new screen
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
unfortunatly the s4 and s4 active arent the same.. you can only buy the lcd + digitizer assembly as one whole peice. which is a good thing really cause this means that the front of the phone is sealed and water tight, i think theyre about 90 pound to buy. which isnt that bad to be fair
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
mophats 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,385
