주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
Why doesnt my LCD work after replacing it?
Hi,
My iphone recently took a bath and the LCD went out. I ordered a new one and went to replace it.
I replaced it successfully but its not turning on. The phone connects fine to the computer I have done a restore on it but nothing seems to work..
Also I have swapped the battery and tried other LCDs with the same issue what could be the problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개:
So the LCD is working the backlight isnt working How do I fix that?
댓글 달기
답변 1개
Have you done anything to address the water damage? At the least, all of the components need to be inspected and cleaned with rubbing alcohol. Check all components for any signs of corrosion. Verify that the sockets for the LCD cable socket on the logic board free of corrosion and are still firmly attached and have not been loosened in the slightest. If they are loose, then the display will not be making good contact. Precision micro-soldering would be required to repair this issue.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Yes, I did ultrasonic cleaning in a 99% alcohol solution. I compared my board to a known good board (with no damage) nothing seemed different. The corrosion was reduced. The cables connecting the LCD are secured well.
When I take a flashlight to the screen I can see text. So the backlight doesnt seem to turn on.
댓글 달기
답변을 추가하세요
Waseem Chaudhry 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 103
