주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
Display is dark not backlit?
If I look real hard I can see a faint image but it seems like the back light is out. Is this the symptom of a bad display unit?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
hi
look for R68 COIL on the board..
u might need to take the top plate off
give a good clean around that coil with cleaning liquid solutions..
clean the lcd connector.
make sure lcd works and is ok..
put everythng back togethor and put the phone on charge straight after assembling..
if didnt worked.
replace the coil 1000% tested and fixed 1000 of those problems..
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You can try these:
Step 1: Check the connectors of screen whether they loosen or not.
Step 2: If the connectors hold in place, take a good look at the LCD with digitizer flex cables, it is the most vulnerable part. If they have been worn, you have to replace the whole LCD screen with digitizer.
Step 3: If the flex cables are intact, the problems still exist. You need to replace the complete LCD screen with digitizer because the LCD is damaged.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mike 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 66
