주요 콘텐츠로 건너뛰기
Updated version of the Kindle Fire 7" tablet by Amazon with 1280x800 HD display. Released September 2012. Repairing this device is straightforward.
101 질문 전체 보기
Why do I have to tap twice on things now to open?
Have had my Kindle Fire hd for about one week. All of a sudden, things wouldn't open unless I tap twice on them, but most of the time, even that doesn't work. It's pretty useless to me know because it's so frustrating. I had a kindle fire, and recently upgraded because I loved my kindle fire. I'm very disappointed that I have had it approx. one week and I can't use it. I've tried everything and nothing works.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글 5개
I can't scroll down to get there, it's just making noise. Is there an other option.
I can not get this to work. In order to double tap I must lift my finger and then it starts back at the first step. Anything else I can do?
Thanks
I woke up this morning and could not get back to my book . Now ...one had to make 3 moves to the one we used to have . Who the !&&* is the idiot who planted this on Kindle. There is no thanks s for this screw up
supoort and follow us.<a href="https://technumus.com/how-to-make-a-book...>HOW TO MAKE A BOOK IN MINECRAFT</a>
I've got a REAL problem. Double tap rarely works. I finally got to the Accessibility page, but the only options available were for Alexa! Anyone help me?
댓글 달기
답변 7개
가장 유용한 답변
I ran into this when I Was learning my Kindle. There is a pull-down menu at the top of the screen where the time is displayed. You will need to tap on it twice, but on the second tap, keep holding down a couple seconds until you can pull down the menu. Once you see the menu, double tap on the far right button (MORE). Scroll down to accessibility, select it, then make certain all three choices are OFF.
In my case this solved the problem. I just duplicated your problem on my Kindle Fire HD7 and this procedure fixed it, so I hope it works for you as well.
해당 답변은 도움이 되었습니까?
점수 6
댓글 7개:
This worked! Thank you. I was getting so frustrated. Now I just need to figure out how to get my audio back.
This also worked for me thank you
This worked, thank you so much, blessings to you!!!!!!!
It worked for me as well, thanks so very much. That was very frustrating. God bless you!
THIS WORKED! Lousey way to have to do things but i am certainly thankful for experts like you!
댓글 2개 더보기
댓글 달기
Thank you! While your answer didn't work for mine, it DID lead me in the right direction! Settings, accessibility, *voiceview*, and that was exactly the problem. Shut Voiceview off, and everything goes back to normal!!! Thanks again!
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thank you I was going nuts trying to figure it out. I was getting ready to send it back
I am pretty sure I have VoiceView ON but cannot seem to find a way to get to where I can turn it off. I can get to a Settings page where the following are located: DEVICE with (Wireless, Power, Display, Alexa, Storage, Apps & Games and Device Options) PERSONAL with (My Account, Parental Controls, Sound & Notification, Profiles & Family Library, Security & Privacy, and Keyboard & Language. I am certain there is more but I cannot swipe the screen. Please give me your best guess.
I got it working, thanks for being there when I needed assistance, even if you weren't available. I went back and reread previous posts and found one that worked.
댓글 달기
I just had the same problem on a newer Kindle fire. Try this. In order to get those settings, double click on the time display in the upper right-hand corner, but on the second tab keep your finger down. Do not lift your finger up. While holding your finger down and then you should drop down that should include settings and a couple of functions that are currently visible. while holding your finger down, drag it over to that drop down and go to the bottom selection which should be voice view settings. that will allow a green highlight to appear around voiceview signifying that you have selected it. It is now safe to lift your finger. Lift your finger, did double tap voice view. That will open the settings for boys for you. Go in and turn it off. It will require a selection of the voice you on off switch, followed by a double tap on the selected switch. What a pain in the ass, but hopefully it works. It did for me. By the way, did I mention that my two-and-a-half-year-old son is the one who changed up all of these settings? LOL
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Unless there is a setting that you changed, it sounds like the digitizer may be failing. I'd exchange it if possible.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
June, 2019, Fire HD 8, like new. I had my tablet in my bag and left the screen on while walking inside with my hands full. I use Amazon Music in the car with the device. I heard a lady mumbling letters and repeating herself. I didn't think anything of it until a day later I attempted to use the tablet. Oh boy! This was much worse than the showroom screen or whatever it's called. I almost lost it. The lady won't stop, the app is all over the place. I am glad I found this thread. I tried asking Alexa all kinds of things hoping to pull open the settings, app, or menu. This was painful. The timing of the taps and the way you tap is very important. I wish you luck. It is a test of true sanity, or what remains.
Alexa had NO IDEA WHAT VOICEVIEW IS. She told me it did not exist on any of my smart devices. (Obviously). I was able to search in the safari search bar for the app. I was then able to press on MY STUFF which is next to WEB and AMAZON (IT WILL SEARCH THOSE PLACES) It said, NO RESULTS FOR VOICE VIEW. I PRESSED THE BLUE HYPERLINK FOR HELP. THE screen came up next with voiceview clear as day, running and on. I switched it OFF.
With patience and a little savvy tech work, you'll get it!!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have been having the same probably with my kindle fire having to use two fingers to scroll, but all of my accessibility buttons have been turned off! Does anyone know what I do to return it to normal?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Just triple tap the power button. It turns off automatically.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dianne Russell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 26
30일 전: 167
전체 시간: 25,853
