주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
white bars at the top of my screen
I replaced my cracked screen, but with the new screen I have horizontal white bars at the top of the xcreen. They only cover the top 1/8 inch of the screen. I've tried re-seating the screen ribbons to the phone, but the problem does not go away.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 달기
답변 8개
가장 유용한 답변
Make sure the LCD connector is clean on both the screen and the logic board, also check to make sure it is seated properly.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Woew, thanks dude :D
Was afraid i had to lose money on a customer
댓글 달기
maybe the replacement screen is bad.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
When reassembling your phone, The LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery. Or you may have a non OEM screen.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Also had the same problem with my 5S.
I bought the LCD from phonepartsfix and they claimed that they LCD is of premium quality.
When the replaced the LCD, I saw white bars on top and bottom of my screen.
Called them again for the replace but they told me to clean the connector and it worked.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I had the same issue, but for me, after some time of usage, the white bars fainted and disappeared without any further action.
해당 답변은 도움이 되었습니까?
점수 0
댓글 6개:
How long did it take to disappear?
If memory serves, the bars were gone after about 2-3 hrs.
Same for me. The blocks faded slowly over an hour or two until they were no longer visible.
Same for me on an iPhone 6 – thanks for the tip :)
I also saw this after replacing the back camera. White bars went away within a couple hours.
댓글 1개 더보기
댓글 달기
After replacing the screen of an Iphone 5, I noticed the white bars at the top. I opened it up again, and cleaned up the connectors. That took care of it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Just replaced my screen and same. Opened her up and reseated connects, whaabam! Good to go.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
any good sites with directions on how to do this? and what to use to clean the connectors? I would assume denatured alcohol? I have an iPhone 5 and two days ago I got the white squares at the top. The squares have since disappeared but now my phone randomly opens apps or sometimes won't recognize screen touches. please help? I've taken an iPhone 4 apart before but am nervous to try my iPhone 5. I can't really afford to replace it.
댓글 달기
I cleaned up the connectors thoroughly and the lines disappeared.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
What did you clean the 3 connectors with?
댓글 달기
귀하의 답변을 추가하세요
Victor Carrola 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 35,270
