주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone 5 verizon no service after replacing powe \ volume control flex
i have replaced the power and volume control flex for iPhone 5 Verizon, now i am getting no signal, everything were put back as is and and i have tried to check if damaged any chips or cables but still no service, formatted and installed the latest IOS still no service, i fixed the date and time again no service,
please help,
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
Once the battery has been disconnected, the phone can use a reboot this way (the best way I found after trying many other combinations):
Connect to iTunes, allow to "trust" so that the iPhone appears in iTunes.
WAIT until the clock has synced, THEN reboot your iPhone by pressing Home Button and Power Button together for 15 seconds. Once the phone restarts, it should connect to the network and stop searching.
Sometimes the network settings are messed up and a Settings>General>Reset>Reset Network Settings may fix it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Also look at Settings>General>About>imei. If your imei number is not showing while in range, you may have issues with your logic board.
If this is the case, reply here to see if there something that can be done still..
댓글 달기
Did you check the inter-connect cables, then long straight is for cellular. Also double check the cellular service antenna next to the battery connector.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Make sure this cable is connected properly
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If all the cables are correctly connected as the other commenters have suggested, try checking the date and time. Often it resets when removing the battery and then won't connect.
Hope I helped.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mohammed 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 783
