주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2013년 9월 10일에 발표된 Apple iPhone 5s에 대한 수리 정보 및 안내서입니다. 모델: A1533, A1453, A1457, A1528, A1530, A1518
Can I replace an iPhone 5s screen with a iPhone 5 screen?
I have cracked my iPhone 5s screen. An iPhone 5 screen is a lot cheaper than a 5s screen. I know the home buttons are different, but I could care less about having touch-ID. So is it possible that I could put an iPhone 5 screen on a 5s?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 42
댓글 8개
Thanks for useful informations.
thank you, the two phone look like each other in outside but are différente inside
Can i use 5s display on iphone 5...?
can i fixed iphone 5 board on 5s
댓글 3개 더보기
댓글 달기
답변 10개
선택된 해법
Unfortunately, you can't. They have different ribbon cable layouts.
이 답변이 도움이 되었나요?
점수 31
댓글 5개:
can i put a iphone 5c screen on a iphone 5s ???
no you can't
I'm use 5s LCD on iPhone 5
can i put 5s disply on 5 motherboard
can i put a iphone 5 screen on a iphone 5s ???
댓글 달기
가장 유용한 답변
Alex is correct. I fix iPhones professionally, and iPhone 5s screens cost 2-3 times more than iPhone 5 screens, at least the high quality ones. The ribbons and brackets are different.
If this was helpful at all, 'accept' my answer, or click the up arrow. :)
이 답변이 도움이 되었나요?
점수 44
댓글 5개:
What about the digitizer
My iPhone 5s screen cracked . its a white iPhone with a white screen . can i replace the screen with a black iPhone 5s screen?
Yeah joe Ive done that the color has no effect on the actual product :)
What the main button on the 5S stay on the phone while changing the screen and if so when you put the 5 screen onto the 5S is would that be compatible what the 5S than still work with the 5 screen on it leaving the button with the 5S on it
Adakah sya boleh menggunakan skrin iphone 5c pada iphone 5s ?
댓글 달기
No you can't, 5/5c/5s screens are not interchangeable.
이 답변이 도움이 되었나요?
점수 12
댓글 2개:
how about the batteries
And how about the cameras
댓글 달기
No, their flex ribbons are different.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Sadly no, one of the major different parts to the 5s and 5 screen is the home button layout one is more spaced out than the other when you place the home button plate over it . It overlaps and there isn't enough space for the ribbon cable and the little plate. NO NO NO NO NO
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
댓글 달기
Unfortunately NO,
The flex cable are different, so you cannot do that.
Sorry :)
이 답변이 도움이 되었나요?
점수 3
댓글 달기
%#*@ thanks y'all. - person who thought they could use a iPhone 5s screen on a iPhone 5.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Can i use ip5 volume button ribbon into ip5s?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Can I put a iPhone 5 screen on my iPhone 5s if I put my home button onto the iPhone 5 screen
이 답변이 도움이 되었나요?
점수 0
댓글 달기
We thought that both are same model (a lil difference)and we can replace screen of iPhone 5s with the iPhone 5 screen.
First of all, both the phones have different power cables attached with the screens.
Moreover, in iPhone 5s there’s fingerprint either of button so it will not set on it properly.
Answered by: Faadee
IG: iamfaadee
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sanchez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 39
전체 시간: 186,796
