주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
질문 마감됨
iPhone 5 shutting down with battery life, then saying no battery
My iPhone 5 has been randomly shutting down (usually with around 10-20% battery remaining), then it gives the dead battery icon until I plug it in. Once I plug it in, it immediately says its got the same battery as before it died. Ive tried deleting apps, tried a factory reset, tried turning off battery consuming processes (push, location awareness, etc.) I am not able to understand the crash reports, but maybe someone else could get some insight there? Do I need to replace the battery itself? Im fine to do that, but something tells me this is a software problem and not a hardware problem. I am really looking for a better way to diagnose the software problem, if that is what it is. I have iOS 7.04, and I dont recall having this problem before iOS7.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It's a new battery you need nothing wrong with the hardware
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
I ordered the new battery kit from here, I look forward to seeing if it works!
That will sort you out.. Let is know how you get on
So far so good, thanks!
Most people that install a new battery and say it's no difference there is damage to one of the components on the motherboard.
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 345
