주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone5 stuck on searching after screen replace
Hi everyone,
I have replaced the screen on my iphone 5, and now it is constantly stuck to "searching". Even if I remove the sim card, I don't get a "no sim inserted", but still a "searching".
I coudn't push the screen all the way in on the top side as the frame is bent. Could it be that it's not working because of this (maybe something is not making contact)?
Or do I have touched something else?
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 7개
가장 유용한 답변
Try turning on airplane mode that turn it off again, if you are still having problems make sure your date and time is correct.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
I have tried with airplane mode, resetting and changing sim. The date and time are correct. No luck
i replaced my screen on my iphone 5c, after turning airplane mode on and off, it fixed the problem
댓글 달기
Can you fix the problem?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I am having the same problem with my iPhone 5s. Replaced the screen and it is working perfectly except for the "searching..." part. I'm not getting reception and when I prop out the sim card, the phone doesn't recognize it is out. I get wifi and everything else is working fine. Any help would be greatly appreciated.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Did you ever get a resolution for this as I am having the exact same problem.
Thanks
댓글 달기
I also need a solution for this issue
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
my i5 did the searching issue and i factory resetted my iphone with itunes through DFU mode. After that i got the no sim issue i took out the sim and inserted it back in i went through the activation screen and it worked hope this helps someone out there.
(if you dont know what dfu mode it search it on youtube its pretty simple)
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i have changed the screen for no reason. i was only looking for another color...............
the same problem for me too/ searching .....
when i bring the old one back to the device/ the problem fixed
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
RESOLVED! Remove metal plate, disconnect battery flex cable as well as the other flex cable next to it. Then connect both cables back and put metal plate back on. This fixed the "No Signal Error" and rear camera error (rear camera stopped working). This may even fix the Touch ID error after replacing LCD screen and or Touch ID home button, but not 100% sure since i haven't tested it yet.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dario Oddenino 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 5,917
