주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
How to unfreeze screen
Screen froze while charging stating that there is not enough storage I cant turn it off and it will not allow me to choose any apps on screen or even slide to unlock or slide to turn off its just stuck please help this phone is my husband and he Is blind and he uses siri for everything,!!!!????????
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 2개
For iPhone user, this method will help you a lot.
How to Unfreeze an iPhone
wow good job
댓글 달기
답변 2개
선택된 답변
Hold down the home button and the power button until the unit shuts down. Then release them both. If the phone doesn't reboot on its own, you may have to press the power button to turn it back on. Make sure that you do not hold the home and power button while the phone restarts because you may accidentally put the unit into DFU mode which would result in losing everything on it - unless you have a program like RecBoot or Tiny Umbrella to kick it out of DFU with!
Good luck!
If you found this to be helpful, please up-vote or Accept Answer.
해당 답변은 도움이 되었습니까?
점수 6
댓글 9개:
OMG! Thank you so much. It worked. It had been frozen for three long days. I had almost given up. Thank you for your posted answer :)
Glad to help Debra!
Thank you! Your a life saver.
Thank you, that worked!!!
I really want to say thank you. Your advice worked. Thank you very much. You have been extremely helpful during a hectic time of my life.
댓글 4개 더보기
댓글 달기
i really need your help.. My iphone 4s Freeze and i can't Turn off it because the Notification Center Hang What i will do to fix it?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I would unscrew the back and take off the wire connecting to the battery then plugging it back it and try turning your phone back on. I think this video is helpful https://www.youtube.com/watch?v=aSUirUBm...
Hi @advadvsdv! I feel terrible that I let your comment hang in limbo so long! Did you get this resolved?
댓글 달기
귀하의 답변을 추가하세요
joann 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 5,237
