주요 콘텐츠로 건너뛰기
Apple Studio Display 15”는 2000년 7월 19일에 출시되었으며 모델 번호 M2454로 식별됩니다.
How to tighten stand on display
I recently replaced the hinge on my display. Now the stand is loose and will not allow the monitor to be a different angles. I can not find a manual anywhere.
Thanks.
Rosemary
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
Check out my link here. Ralph
http://docs.google.com/viewer?a=v&q=cach...
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
nice link +
Looks like this link is dead. I too would appreciate any insight into a replacement hinge / mounting plate / bracket.
댓글 달기
Where did you find the hinge? I need to replace mine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
A friend gave me the 20" version of this monitor over the summer with the same issue. I thought I could find a replacement hinge on ebay or other secondary market. No luck. They were either for the wrong size or too expensive.
I had the thought of putting it in a fixed position by tapping it with a screw, but it is not made like that. Where I thought I could tap is only plastic. No luck, but a thought. Reverse it.
I turned the hinge around. You need to slide the ferrite filter to the other side. There are three index marks that will need to be filed down. Screw it back down and replace the cover and stand.
It now seats on my desk at little greater than 90°s, no slide. Gravity should keep it from coming forward.
Ok, I could have tried to set it as it was by tightening the nuts on the ends of the hinge. But I could have over tightened (not mentioned in the manual) and snapped them off and/or it might still be loose.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rosemary 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 16
전체 시간: 2,625
