주요 콘텐츠로 건너뛰기
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 질문 전체 보기
질문 마감됨
Unable to turn it on
Hi,
Perfectly working fine and suddenly stopped working and not starting now. Unable t turn it on. Not even showing any battery charging icon when connected to charger. What could be the problem. When trying to start, shows slightly grey screen for 1 second and switches off. Tried press/hold sleep button but no success. Can any one help please.
Thank you
kind regards
suman
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hold power and home button togeather for 7 seconds then let go of home but keep power held down this should kick start it with the apple logo
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
Glad this worked for you
I just tried this and it worked perfect...THANK YOU SO MUCH
댓글 달기
Just to add to the discussion a little bit, I do believe this is caused when you repair the Ipad while it's started. Ensure that the unti is powered down before doing any reperation in the future to avoid any damage. :)
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 264
