주요 콘텐츠로 건너뛰기
The Asus X53E is a 15.6-inch Windows laptop released by Asus in 2011.
15 질문 전체 보기
contact failure on the computer connector to electricity network
How can I open the computer to look inside where the problem lies?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
Before opening I would check the power adapter. Can you locate a second power adapter to try out? Or access to a second system (Asus X53E) to try your power adapter on?
Is the connectors clean and not damaged (adapter & system)? If they are dirty unplug the adapter then with a cotton swab (Q-Tip) with some Isopropyl alcohol wipe the contacts. Any better?
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
recurent prob on asus x53s.
it cames from the dc connector soldered on the MB.
have to change it.
the good news is that it's a relatively cheap spare parts.
the bad news is that you have to got some skills to unsolder the part from the MB.
be carefull not to broke the small and thin MB part on which the connector is soldered. it broke easily if you're too rough.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
you might want to do this using hot air and solder paste. It'll save you some headaches and cash.
댓글 달기
귀하의 답변을 추가하세요
Agathe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 2,110
