주요 콘텐츠로 건너뛰기
Power Mac G4에는 Mirrored Drive Doors가 있습니다.
cpu changeout, is it the cpu or motherboard?
I am a Mac newby by need of having run an old program on OS 9. I got a MDD, and after about a week, it will no longer start up. The light on the start button flashes, but nothing happens. I tried changing the the power supply, and that did not help, so I assume it is a bad motherboard or CPU. Any way to tell which? Last, what is the trick to release the CPU board from the motherboard? I have been checking this site, and have not found it. Thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
First, replace the 3.6 volt PRAM battery and see if your problem has vanished.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
I did that...matter of fact a guy "Mac superstore lead me astray"; when trying a different battery did not help, he said it was the power supply. I then rewired an ATX power supply to use on the MDD per youtube video. Now I have to undo that!
My computer is working again. I found a reset button on the motherboard. I also found out the hard way that an ATX power supply can be used
if it is wired to the MDD harness.
댓글 달기
답변을 추가하세요
Peter Bresler 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 1,010
