주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Dried out iPhone Won't stay powered up long enough to pull pictures
President of the company got his iPhone 4s wet and now wants me to grab the pictures off of it. We have given him a new phone so there is no cell service on the old phone. The old phone has been dried out and powers up fine when you connect it to a wall charger. I can see the pictures but I have no way to transfer them via MMS, bluetooth or WiFI as non of those services are functioning. If i connect the phone to a MAC or PC via USB there isn't enough power to start-up the device. I've sent it out to DriveSavers to see if they could pull anything off but they ran into the same problem.
Any suggestions on other ways to try to get these pictures off of the phone? The user has of course never backed anything up or ever synched with another device.
I have pulled the unit apart and removed the battery and then when I connect it using USB I at least get an Apple logo before it goes into a restart loop.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
Progress! The new battery definitely helped. I now get the iTunes and USB graphic and the when I connect to my PC, the device stays powered on. The device driver loads and so does iTunes. iTunes detects the device as in recovery mode. I choose to not to restore the iPhone and cancel iTunes. When I run iFunBox it does not detect the device. Am I screwed?
It's not detecting it because it's in recovery mode
There is another program called iPhone backup extracter I would download that and see does that detect the backup but I'm sure it won't because it's in recovery
First download tiny umbrella when u open up it will give you the option to exit recovery try that see if it works
No luck. tried tiny umbrella but I'm still stuck at the iTunes/USB graphic. Is it worth trying Backup Extractor?
댓글 달기
답변 3개
가장 유용한 답변
Get new battery or borrow a 4s battery when phone starts up you can use ifunbox to transfer photos off the computer
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
New battery!!
Will it not power up when plugged into iTunes in computer?
댓글 달기
You need a new battery for sure, iphones will not go past the apple boot logo without one.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If you disconnect your new battery and phone still starts in recovery mode, you are in trouble if redsn0w or tiny umbrella doesn't kick it out of recovery.
If you get out of recovery,
And If a freshly charged battery doesn't allow iTunes to recognize the device, then the other choice is to fix the wifi. Find someone to replace blue coil and you're done.
Jessa
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Are you saying to replace this: [연계 제품이 누락 또는 비활성화 됨: IF115-018] ?
If I just power up the device on the wall charger it comes up normally and I can see the pictures I want and all the installed apps. So if you think getting the WiFi to work will allow me to download the pictures I will give it a try.
No---not that. After water damage, it is typical for the blue coil on the motherboard to fail which causes the wifi option to be greyed out. google 'blue coil wifi' for more info--i can't provide any more details right now but i will check back later.
댓글 달기
귀하의 답변을 추가하세요
tcornell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 21
전체 시간: 1,644
