주요 콘텐츠로 건너뛰기
모델 M6497 또는 A1005 / 500, 600, 700, 800, 또는 900 MHz G3 processor
117 질문 전체 보기
Can not install OS X Jaguar nor Panther on my IBook G3 900 MHz 12"
My IBook was running fine with OS X 10.3.9, after attemting to install Tiger 10.4.x on it, the install program self aborted with a message of "errors detected".
Now seems that my HD 40 GB is "corrupted" and I am not capable of re-instaling even the 10.2.x OS X. I have tried to repair the disk with the DISK UTILITY which is enclosed in the original install disk but has nor possible to repair, erase or anything else.
I even tried with DBAN CD, but the program does not show any progress after hours running.
What can I do?
Thanks for your help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Well, you've definitely tried most of my suggestions already.
You could try using firewire 400 to connect it to another mac, from that mac you could try erasing the hard drive with disc utility and then re-imaging it with either the image from that mac or the image from your discs.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Looks like your HDD has non-reprable damage, it needs then to be replaced. Check this guide for instructions:
iBook G3 12" Hard Drive Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Rferrer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 1,987
