주요 콘텐츠로 건너뛰기
2011년 7월 21일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Thunderbolt. 이 기기는 Mac mini Server 구성을 실행하는데도 사용됩니다.
204 질문 전체 보기
Are my Mac mini 2011 IR and Fan connectors broken
I lifted these off using a plastic prying tool, but I can't them back on...are these pins that stick into holes? Because all I see are the metal parts but there are no pins, leading me to believe that I snapped off the pins and the four metal things that I see on the logic board are the snapped off halves?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
선택된 답변
Yes, you've snapped off the fan connector from the logic board. The four pins are the power connectors. The back two pins help hold the connector to the logic board. I've just done the same thing. That'll teach me for starting a project at 11 PM in dim light.
See this post for more information: Fan Connector Broken on Logic Board
It looks like an expensive third party logic board repair for both of us.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Subsequent to this reply, I found a fellow from a local university who does microscopic soldering. 20 minutes and $50 CAD later the Mac mini was up and running again, and is still running fine to this day (2016/03/13).
댓글 달기
You have some bare fan wires? That looks like a fan or IR connector to me.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Peijin Chen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 12
30일 전: 27
전체 시간: 1,511
