주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Why is my screen black after I dropped it?
i dropped my phone on the floor and then i picked it up as soon as i could! when it hit the floor back down, the screen slowly turned all red, then completely black. it still vibrates, charges, and makes noises. i dont know why the screen is black! i tried getting into the back of my phone and i was making sure everything was in place and in order. i tried resetting it too. help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 11
댓글 달기
답변 4개
가장 유용한 답변
The lcd connecter could have popped out make sure it is still connected but by saying the screen turned red the black I think you have busted the lcd and need a replacement
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
My phone did the same thing and I didn't no what to do I thought I broke a pixel but I don't no if I did will a screen replacement fix it?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I need to know this too my phone did the same thing should i just replace my screen or take in into apple?
댓글 달기
Both of you need a screen replacement, luckily this is very very easy on a iPhone 5C and the full assembly with backplate, home button and lcd in one should only cost a little over $10. follow the guide from ifxit slowly and you should have a good screen all fixed in around 30 minutes.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Same thing happened, my phone fell to the ground and it was black when i grabbed it
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
amanda 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 7,666
