주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
질문 마감됨
Leftover part after Volume button cleaned
I changed the battery and cleaned the Volume button on my iPhone 4S, everything seemed to go alright but a part fell out while I was tilting the phone to lift out one of the phillips head screws I had removed. I went through a lot of tear down pictures and looked for other posts that might have that part left over. It is a short piece of metal braided tubing that appears to have foam in the center. About 2mm long and about the same width when flattened.
I have it next to the pentalobe dock connector screw for scale. I thought the cell signal was gone at first because the phone showed "searching..." in the bar indicator, I switched in and out of Airplane mode and it seems to be fine now.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Thank you! Glad to hear it is not critical but I will put it back.
댓글 달기
답변 1개
선택된 답변
Hi there this is a little cushion it sits in between the dock flex and the frame.
It is not needed but if your a perfectionist like me you'll put it back lol
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 86
