주요 콘텐츠로 건너뛰기
2011년 2월에 출시된 Samsung Galaxy Ace는 Adreno 200 GPU, 800MHz Qualcomm MSM7227 프로세서를 장착한 Samsung 스마트폰입니다.
31 질문 전체 보기
Samsung Galaxy Ace Plus is shutting on and off by itself?
My phone ran out of battery and I put it to charge, after charging I turned on the phone... The phone shows Samsung, then the model and shuts off by itself and goes on a loop of turning off and on.
I thought it might be the battery so I bought one... Same thing happens when I installed the new battery, then if thought it might be that the phone doesn't charge so I bought a battery charger to proof that theory. I charged the batteries only to discover that the phone goes on the same loop of turning on and off by itself. Does anyone have any idea what can it be? Thank you for any help you can give me.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 3개
My phone turn off that day and wont turn on until now . But when i try to start , it only came out the battery symbol and keeps vibrating .
My samsung galaxy J1 ace also had the same problem what should i do?
Yes A solution is present if your mobile memory is full then it starts on and off and to solve this problem you can reset the mobile by pressing home button +volume up+power button and then reset the mobile from there and then mobile will work normall as it is...thankyou
댓글 달기
답변 6개
선택된 답변
Hold down your power button + your volume up button. Continue to hold maybe, 25 - 30 seconds? To my knowledge, that'll reset the device. if that doesn't work, I would try getting into the 'recovery menu' and restore your device that way.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Yes a hard reset fixed it! THANKS
댓글 달기
I have also had the similar problem. Phone was fine for 12 months or so that I have had it but then it did an
Automatic software update and I have had the problem ever since, about 2weeks onow.
One of the 2degrees guys suggested that the new software was not compatible with this phone. Typical android which is why IOS has it all over them.
Colin
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
itself off and on
how to fix ace4 itself tuning off and on
댓글 달기
I have the same problem, my phone is stuck in some type of restarting loop. Its not the battery that is the problem with me either and i haven't come into contact with water, I've seen people talking about a power button problem, I asked a question about it hopefully it gets answered
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My phone did come in contact with water
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
It blowed an IC
댓글 달기
I dont KNoew wht is up
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Same thing with phone i have, wont stay on
my problem is ,it power its self off and on.even if i try touch on the scrn ,it goes off Galaxy [ace 3 samsung]
댓글 달기
I have a Samsung ace 5830i that when goes into sleep mode it turns it off completely
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Olyme 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 11,053
