주요 콘텐츠로 건너뛰기
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 질문 전체 보기
Extra part while reassembling my portafilter.
Help. I think I have everything correct on putting my portafilter back together EXCEPT: on large c-shaped metal wire/ring with on end looped and the other bent up. Where did that come from??
I have checked all charts online I could find. No luck!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
Katheryn, that is the handle return spring... It fits between the portafilter housing and the plastic valve assembly. To get to it, separate the plastic portafilter handle by removing the three phillips head screws and their bushings. Carefully remove the heavy portafilter housing, and be sure to not lose the coiled valve spring. Next, remove the coiled valve spring and set it aside. Then hinge open the outlet valve pin so that you can see the center four pronged center hub of the plastic portafilter valve assemble. WIth a butter knife, carefully wedge up the plastic assembly until it clears the four retention prongs. Flip over the assembly, and you will see two distinct pin bumps that are integrated into the plastic assembly. The looped end of the c-shaped ring goes over the larger of the two pins. Place the looped end over the pin and press it against the plastic assembly body. Hold the wire fast to the assembly and then bend the wire around so that the bend around the other end is held tight against the other pin. I have enclosed a picture for your reference. When putting the assembly back together, insure that the larger of the two pins is placed into the round corresponding portafilter housing recess as you press the plastic assembly back onto the portafilter housing. Let me know how it goes. Leo
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thank you, Leo! I couldn't find an enclosed picture for reference, but I think your explanation should walk me through it. I appreciate your time.
Kathryn
댓글 달기
이미지 내용 보기:
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Sorry about the picture problem, it wasn't in the correct resolution. The picture is now enclosed as it should be. Glad to be of service. Oddly, just reading this post made me disassemble my portafilter assembly, and it was pretty dirty, so I cleaned mine too. You see, not all problems are problems.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kathryn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 171
