주요 콘텐츠로 건너뛰기
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
20 질문 전체 보기
Why isn't my battery charging?
I put my charger in my Samsung Galaxy Tab 2 tablet to charge it up last night and it keeps saying it isn't charging. It has the charging icon but has a red cross even if i take the charger out. What do I do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 19
댓글 2개
What kind of charger are you using?
dont use charger below than Tab 2
댓글 달기
답변 4개
가장 유용한 답변
Emily Denton, I'd suggest that you plug the charger in, then hold volume up and down buttons down at same time for about 10 seconds and release after. Your boot up screen should come on and your battery should be low. Turn your device off and let it charge normally. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 3
댓글 5개:
This worked on mine screen went black but loaded like a reboot and my battery is now charging
Wow! Thank you so much for the tip <3
new battery from service center for Galaxy Tab 3 but charging problem is even worse. what in the world?
Worked for mine! Awesome! Thank you! :)
Will this method get rid of all my apps and files?
댓글 달기
I opened the tablet up, disconnected the battery wire (just used a small blunt object underneath and popped it up), took the battery out and waited a minute. Put the battery back in, connected the wire back on, put the backing back on the tablet and plugged it in. It worked. There are tutorials on youtube on how to replace the battery. Although I was not replacing the battery, simply just re setting it, that's how I got mine to start charging again. Good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My tablet is charged when I take out cable the charging goes low tal me what I do
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You should try changing outlets. If it doesn't work...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Emily Denton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 41,044
