주요 콘텐츠로 건너뛰기
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 질문 전체 보기
Problem with wifi signal level after repair (changing LCD display)
Hi,
after replacing the LCD unit of my Razr XT910, I got a problem with very low wifi signal level. Is it possible that I have damaged the wireless antenna ? The GPS is not connecting, too. However, it was not connecting before I replace the LCD. I am still in doubt where it is really positioned the wifi antenna.
Best regards,
Heron
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
With little documentation out there, and not having that specific model on me I looked at a couple of teardowns and images of the parts. There is two antenna's I can see on the mid frame (rear housing). One near the top, the other near the bottom. The larger of the two will most likely be cellular.
There is also a possible antenna on the LCD flex cable. I would generally think its a IC but from lack of traces leading to it, just can't be.
As for the GPS, antennas are usually in the controller for it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Heron Carvalho 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 1,199
