주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
Adapter for MBA 13" Mid 2013 PCIe drive to SATA or USB?
Hello everyone,
I work at a computer repair shop and since the new MacBook Airs have been out for a bit, we have come across instances where we are unable to get data from a machine simply because we don't have the tool to do it.
I am looking for an adapter that will take the PCIe SSD in a Mid/Late 2013 MacBook Air (or MacBook Pro Retina Mid/Late 2013) SSD to either SATA or USB.
So far, any searches have come up empty.
Any help would be appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 2개
Would this type of drive work in a Mini PCIe slot like what many systems have for Wifi/BT card?
sintech has them but they are expensive
댓글 달기
답변 2개
선택된 답변
I've faced the same problem! Sadly, there is no options right now. There are no external drive cases for the newer PCIe drives currently.
What I do is use a second '13 Air popping the SSD into it and then putting it into Target Mode with a USB cable copy off what was needed.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
That is what I have been doing. Maybe, just maybe, we will get something.
Thanks
I am looking for an adapter of my macbook pro 2013 ssd to a data 2.5 inch enclosure . Planning to use it in my 2012 macbook pro i7ghz.
Any help or suggestions is great appreciated!
댓글 달기
I've found some 2013-2014 ssd to pcie adapters on ebay. Doesn't really help unless you have a mac pro to pop the ssd into or have a pcie to thunderbolt enclosure (which run about $400 ata minimum).
http://www.ebay.com/itm/2013-2014-MacBoo...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nathan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 10,525
