주요 콘텐츠로 건너뛰기
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
How to fix wifi and Bluetooth issues?
Hi all. Hope you can help me fixing my HTC one x. It dropped on the floor and wifi and Bluetooth doesn't work anymore. Do you know where wifi and Bluetooth chips are so i can buy the right component to fix the phone? Thanks for your answer. Have a good day!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Looking at the back of the phone, press in the upper right hand corner and hold it there, see if you can get a signal. A quick simple fix for this without opening the device can be to get a plastic hard case and something as simple as a puzzle piece, insert puzzle piece into upper right corner of case, ensure doesn't block camera, and insert phone, see if this doesn't help. Sound weird? Here's proof http://www.youtube.com/watch?v=z8Ha8tkiJ...
Other than that I would suggest opening up the phone and ensure all cables are connected and seated correctly
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks for tour help. The phone has an hw problem for sure. Before buying a broken one x to fix mine, I have to know which is the component to replace. Where WiFi and bluetooth chipset are ? On the mono ?
댓글 달기
Here's a few options that you could do:
1. Go on your local buying/selling website (America is Craigslist) and try to find a broken HTC One X, maybe they're selling cheap because of a cracked screen. Just stay away from any Water damaged ones.
2. Go to Ebay and look for specific parts, if you don't want to do it yourself, save yourself the trouble and buy the parts (which makes it cheaper on you) and bring it to a local shop and they'll replace it for you.
3. If all else fails, you'll have to take it to a repair shop. Make sure the repair shop is reputable so you're not being screwed over in anyway possible.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Andrea 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 4,955
