주요 콘텐츠로 건너뛰기
Repair guides for Android cell phones manufactured by HTC.
1321 질문 전체 보기
HTC M7 battery replacement compatibility
Hi! I need to repair my HTC One M7 display. so i'm thinking to change also the battery. But i want to know if the HTC One M8 battery has the same dimensions of mine M7 for replace it (like HTC One X and One X+).
Thanks for answer!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
I can't find much information about the M8's battery dimensions online but I did find that it is rated at 2600MaH and the M7's is rated at 2300Mah. Aside from not being a very large improvement, higher battery capacity almost always means a bigger battery so changes are, they aren't compatible. I looked at a picture in the M8 iFixit teardown and the battery looks similar to the M7, but it could be thicker. I wouldn't recommend taking the risk. Also, I didn't find anywhere where you can even buy an M8 battery.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Luigi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 2,025
