주요 콘텐츠로 건너뛰기
모델 A1046 또는 A1095 / 1280x854 스크린 해상도
118 질문 전체 보기
Hard drive cable plug in
Hi,
I guess I screwed up putting in a new 120GB hard drive. The computer doesn't see any hard drive. I was more concerned about removing the cable from the hard drive without bending any pins and I think I plugged it in wrong. There are 2 rows of pins on the left side of the pins and then a space and I am not sure if I start the cable there or skip those 2 rows and plug it in? Thanks.
Thanks...I went to the other side...Will switch it tomorrow when I am more focused and not bummed
I opened it up again and everything was connected correctly. Did this a few more times since it still would not see the HD. The last time as it started the install and no HD to put it on I went to the Utility program and it saw the HD. I erased it and started the install. It is going along well.
Thanks to all for the help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Hi! I pasted in a link below to a picture of the pins on a hard drive. Looking at the picture, you want the plug to cover the big chunk of 2 rows of pins on the right side. If that means the 4 pins to the left that are separated by a space are not connected to the plug, that is fine -- some plugs cover the additional pins, and some don't.
http://www.datarecoverytutorial.com/wp-i...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Also notice the missing pin. You should have a blank spot on the connector that fits that spot. Ralph
댓글 달기
귀하의 답변을 추가하세요
andersong 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,666
