I replaced my S4 LCD Screen, how do I get the sound working again?
I cracked my Lcd and had to order a new one. installed it, now I have no sound. Is there any way of fixing it?
좋은 질문 입니까?
좋은 질문 입니까?
Solutions for loudspeaker for Galaxy S4 I9505 no sound problem(from http://www.witrigs.com/replacement-parts...)
When external speaker for Galaxy S4 I9505 is broken, your phone doesn’t ring, sound notified or plays music/videos out. But if you plug the headphones in, everything comes back again. Bringing such a huge annoyance, it is speaker for Galaxy S4 not working that becomes a must solve problem.
Step 1. Check the setting
Go into the settings > sound > volume, make sure you didn’t turn on the vibration or silent switch, adjust the volume for music, ringtones and notifications, and then to hear if the Galaxy S4 no sound still.
Step 2. Reboot the phone
Hold on the power button and choose the restart option, hopefully do like this will eliminate any glitches causing the problem.
Step 3. Update software
For those who have not update OS, it will be a nice try. For others, you can find other ways to solve the problem of Galaxy S4 no sound.
Step 4. Replace loudspeaker
If all above the steps are failed, what you should consider is hardware problem and to replace a new speaker enclosure. If the trouble that speaker for Galaxy S4 not working still exists, send it to the repair center for checking the logic board.
Also, you should make sure if your USB board is installed well, because the loudspeaker is connected with it by two spring chips.
해당 답변은 도움이 되었습니까?
None of those things worked for me so I downloaded an equalizer app and that fixed my problem.
I also had a similar issue. After completing the screen repair the in-call audio is diverted to bluetooth even when the bluetooth is turned off. Connecting to a bluetooth device is the only way to hear anything, incoming or outgoing. I'm more than certain it's not a hardware issue. Might either of you have an idea that may help?
해당 답변은 도움이 되었습니까?
I have the same problem, did you figure out any solution?
I have a samsung s4 and i cant hear the sound or music it has interior screen damage what can i do to make it work
해당 답변은 도움이 되었습니까?
i faced the same problem.my connection of the loudspeaker was loose .i tried to fix that.and it worked
해당 답변은 도움이 되었습니까?
Take off the back cover, unscrew the 4 bottom screws.
Gently pry the gray bottom that has the silver speaker on it.
blow on the inside of the phone, blow on the inside of the casing you removed
Click the casing back making sure all the connections are tight, make sure
You screw it in tight but not too tight.
That should work
If not get a replacement part for the part piece with the silver speaker
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 7
30일 전: 13
전체 시간: 8,560
댓글 1개
parham asgari 의
