주요 콘텐츠로 건너뛰기
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 질문 전체 보기
My iPad's screen has wierd colors.
Okay so my iPad was dropped on the floor, the screen went black but when I press the lock button it showed a little light, I found a solution here, I smacked the iPad and the screen turned on again, but the screen has wierd colours like orange - red - green - blue greeny and I tried to search here for solutions but I didn't find any. So can I fix it with smacking again or do I have to go and change the LCD or what? And thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 6개
가장 유용한 답변
I'm definitely no Ipad pro, but if you are comfortable with DIY solutions I would suggest simply opening the Ipad 2 (remove the digitizer) and ensure that the LCD coord is seated correctly. What happened when you dropped it in the first place was the cable got slightly unseated, and when you smack it (sometimes) it gets back into place.
I have customers who come in once a week saying they need a new LCD, 6times out of 10 I simply unconnect and reconnect the cable and it works as it should.
If reseating the coord does not fix the problem, then you will indeed need to purchase a new LCD for your Ipad.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Before you go tearing it apart , try some more smacks. Be sure to go around all the four corners. If this doesn't work after a few tries, then go with Alexanders advice. Make sure the iPad is powered off before disconnecting/reconnecting the LCD cable as you could blow the backlight filter if it is still powered on.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Smack the back
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Lovely! It worked like a swiss clock.
I tried it and to my surprise it worked
Give it few slaps, still getting array of colours. What next? Thankyou.
댓글 달기
Another thing to verify...make sure you didn't activate the "Invert Colors" option. This will effect all the colors. It is possible the home button is programmed to activate it by pressing 3 times quickly.
To verify:
1. Go to "Settings"
2. Scroll to "General"
3. Make sure the "Invert Colors" slider is to the left for normal operation.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
So I dropped my iPad and had the red screen. Tried smacking it and didn't help. Went to check invert colors and it was off but I slid it over to see what it would look like. Decided I didn't like it and switched it back. Went to home screen and all was fixed
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
iPad color change issue started after I purchased a after market non Apple charging cable. There were no problems at first. It was a couple weeks later before the color change occurred. Took it to Apple store. Said to buy a new one. Well no thanks, I’ll wait to upgrade to the Pro. I decided to only use the alt cord when I was too far from an outlet. I started using the original cord again to charge the iPad. After several charges and complete discharges, the last one sitting for 3-4 days before charging, the color changed back.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Xobic 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 24
전체 시간: 21,583
