주요 콘텐츠로 건너뛰기
Samsung의 5-세대 Android-기반 Galaxy 스마트폰은 2014년 4월 11일에 출시되었습니다. 이 휴대폰은 지문 스캐너, 최신 카메라, 대형 화면 및 방수 기능이 개선되었습니다. 네 가지 색상으로 제공됩니다; 검정, 파랑, 흰색 및 구리.
577 질문 전체 보기
The display for the phone is blank, but the phone still works
So I'm walking from one building to another, and the there is a slight drizzle outside (not a lot of rain) so I take out my phone for a quick second to check some messages and put it back into my pocket. When I get into the building (about 5 minutes tops) the display is black, but the lights on the bottom of the phone turn on, and when I do my pattern I can unlock my phone. So the phone still works, but the display is black. Any tips? also I don't know if the Galaxy has a reset like an iPhone does, so if you tell me I need to reset it, please tell me how to do so. Thank you for the help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
There is a way to reset the phone in the settings menu, but with the display being black that would be impossible to get to.
I would first try restarting the phone by removing the battery, reinserting it and then holding the power button down. If that does not fix it, there might be something wrong with the display or the display back-lighting. In that case the only option would be to replace the screen.
Luckily, you may still be under warranty since the phone is designed to be water resistant. You could probably have Samsung fix it for free.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This has happened to me recently with my s5 at 4 weeks old, I sent it back to o2 here in the uk under warranty for repair. They diagnosed it as the LED for the screen is cracked and will not repair it.
Now this phone is pristine condition and is always wrapped up in an otterbox case since it first got turned on. Apparently I have "misused" the s5......WTF! Ive now wasted £700 on a phone that is useless!
Insure your phones people as the quote for the repairs was just over £300 including Vat.
Ben
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Stephen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 565
