주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone 5 earpiece speaker quit working.
My earpiece speaker quit working. It went all at once - not intermittent. I didn't drop it. I replaced the speaker, but it's still not working. I did a hard reset on it. I plugged in the headphone jack a couple of times. I see that the speaker has spring contacts, but I didn't clean under them during replacement. I did plug my phone into the iPad charger the day before it quit working. Is my logic board toast? I will clean under the speaker contacts, but any other suggestions would be greatly appreciated before I buy a board - or worse a new phone. I'm only able to use it on speakerphone now. Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
It could be that you need a camera/proximity flex as this powers the earpiece..
Just make sure the gold prongs are touching the gold contacts
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Just make sure the gold contacts are lined up if they are and it still doesn't work then try a new cable
I saw that the speaker gets its power from the camera, so I verified that the camera/proximity sensor are working. Could the cable still be the issue? I haven't taken it back apart yet.
댓글 달기
i am having the same issue, replaced the earpiece but think that if i change that cable it may be the problem. if i push hard on the back it works but not well.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I replaced the front camera/proximity sensor cable and now I have sound in the earpiece! Thanks for helping.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kyle Nabors 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 393
