주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Can't slide to unlock stuck in welcome screen
i did
soft reset
hard reset
can connect to pc i did factory reset
i replace the digitazer and screen, still no slide
is like blind or no sensitivity at all
some one tell me replace the digi
didn't help
don't know what to do
by the way in itunes when i do the factory reset
says congratulations you iphone is unlocked
don't know if is factory unlock or what..
today i put it in alcohol i will see tomorrow
i am getting good in taking this thing apart!!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개:
Why are you planing on placing it in alcohol? Any water damage to this phone?
the water color thing is red, thats why,
by the way all the buttons are working good, just is not sensitivity on the phone
댓글 달기
답변 1개
roy, there is the possibility that your digitizer is defective. Double check your work and see if everything is correctly seated. Try your new digitizer on another phone, or try another new digitizer. It is not uncommon to get replacements that have a faulty digitizer. Should it still not work with another new one, you may have issues with the touch controller IC on the logic board. This would be a major repair since it would require a reball of the IC. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
i will try that later, we have other phone 4 with a beatyfull crack on the screen, i wil check both digis
댓글 달기
귀하의 답변을 추가하세요
roy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 4,547
