주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 모델 i9505는 13-megapixel 후면 카메라 및 5-inch 1080p 화면이 특징입니다.
526 질문 전체 보기
How to apply Galaxy s4 glass adhesive
Hi you all, in few days I will get a replacement glass for my Samsung galaxy s4, that includes an adhesive like this one http://www.ebay.it/itm/3MM-Digitizer-Tou...
Now I know that I'll have to apply an huge adhesive on the back of the glass itself, in order to paste it on the metal frame of the phone.
The question is: it is better to apply that adhesive FIRST on the LCD, and THEN apply the glass, or it's better to apply the adhesive directly on the back of the glass and then make it fit the phone's body?
Thank you in advantage.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
First, stick the adhesive on the edges of LCD supporting frame, then press your glass on. It's not on the screen but on the frame.
On the other hand, there may need other glue on whole back of the glass. Because when you remove it, you can find there are a lot glue under the glass back.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Ok thank you so much, I will try.
댓글 달기
귀하의 답변을 추가하세요
Lorenzo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 4,066
