After screen repair, digitizer not working. What next?
Replaced logic board and another new digitizer. Still not responding .
좋은 질문 입니까?
좋은 질문 입니까?
You probably have the wrong version digitizer. Check the cable of the original glass and look at the revision.
해당 답변은 도움이 되었습니까?
You're right! Got the same thing, mixed up revision versions and the digitizer did not respond to anything. Worked again when I matched rev 0.0 with another rev 0.0
where did you find the one that said rev 0.0?
Got it off eBay by a Dutch member called ts-shops for 27,50 euro
I have a tab t555 and same issue. where can I get a rev 0.0. or what if I change the connector on the board?
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 2,505
댓글 2개
my grandson damaged the digitizer on the tab2 can this be fixed or replaced???
Barbara 의
How would one go about getting a digitizer with the correct version.
Stephen Hood 의
