주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2201 질문 전체 보기
iPhone 4s Error 29, changed battery - nothing works
So I dropped it on the floor, It worked fine until it discharged a day later, It wouldn't recharge, went into restore mode got error 29 restore loop. Tried DFU same results.
Got a new battery, nothing changed. Took it to a shop they said board is busted I should buy a new phone.
I'm posting the error log here maybe someone has an idea what's wrong.
[18:54:27.0553] entering update_gas_gauge
[18:54:27.0553] AppleImage3NORAccess::_getSuperBlock imageVersion: 3
[18:54:27.0553] [nand_part_core:INF@2289] first 2 pages of boot blocks written with copies of partition table
[18:54:27.0553] [nand_part_core:INF@3169] next 98 pages of boot blocks written with LLB image of size 150080 bytes
[18:54:27.0553] [nand_part_core:INF@3172] final 156 pages of boot blocks written with random data in full page format
[18:54:27.0553] 0: RamrodErrorDomain/3ea: update_gas_gauge: gasgauge_swupdate returned -1
[18:54:27.0553] restore failed with CFError:
[18:54:27.0553] 0: AMRestoreErrorDomain/1d: failed to update device firmware
[18:54:27.0553] 1: AMRestoreErrorDomain/1d: ramrod firmware update failed
[18:54:27.0553] 2: RamrodErrorDomain/3ea: update_gas_gauge: gasgauge_swupdate returned -1
[18:54:27.0553] waiting for host to acknowledge final status received...
[18:54:27.0553] host received final status
[18:54:27.0553] attempting to dump restore log
Thank you in advance :)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
가장 유용한 답변
Replacing the battery mostly resolves this issue.
If this does not do it, replace the chargeflex also.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Just went through this and the battery change did the trick.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Basically if you've exhausted all the other fixes... changing the battery,removing firewall,antivirus,editing host file etc etc. Then check the last line of your itunes restore log if it says something like...'RamrodErrorr domain/3ea: update_gas_gauge: gasgauge_swupdate returned -1' ... Ifixit has the answer and more details here.....
Enable GPS even when phone is off... .
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Shaise 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 4,886
