주요 콘텐츠로 건너뛰기
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
139 질문 전체 보기
Engine cutting off when brake/clutch pedal released
I have a Murray riding mower model 46503X8.
I depress the clutch brake pedal to start the engine. The engine starts easily and runs when the brake/clutch switch is depressed.
If I release the brake/clutch switch the engine shuts down. I replaced the brake /clutch switch and the pto switch, but the problem did not go away.
I did the following test. With the engine running and the brake /clutch switch depress, I engaged the cutting blades (pto switch) and the engine shuts down.
I have an electrical diagram but need help to solve this problem.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
Further checks revealed that the seat switch was defective. Once I replaced this, I was running and cutting the grass.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I had the same problem with the brake pedal but my seat safety switch was disabled before the problem arised.... and everything worked fine ???
댓글 달기
귀하의 답변을 추가하세요
Harry 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 18
30일 전: 101
전체 시간: 17,393
