주요 콘텐츠로 건너뛰기
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 질문 전체 보기
Half black LCD after digitizer replace
Hi I could really use some help! After several days of googling I've not found a good answer and I'm loathe to buy new parts before knowing the answer. I just did an antenna (wifi, 3G, GPS) and digitizer replace. LCD was working fine before replace but now I only get half a white screen. The other half is black and sometimes black with red and blue lines. Other times the LCD is dim with three black bars. iTunes does recognize and I've done a hard reset, and a full recovery/restore. I've checked the connection and seating of all the wires and I can't see any issues. Is this an LCD problem? A logic board problem? I've already bought a bunch of parts and don't want to put anymore $ in until I know what the possible issue is! Thanks in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
Hi there it sounds like you have damaged lcd you will need to get another to find out
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
rgarbee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 291
